Domain permissions in StruxureWare Building Operation.
  • Domain permissions in StruxureWare Building Operation.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:07 AM
When sharing the domain with the AS under an ES, the domain object appears but includes no Users or User Groups.
  • Domains
  • Users
  • User Groups
  • Permissions
Need an efficient way to distribute and administer permissions to all Automation Servers.
  • When you share a domain in the ES with an Automation Server, the Users and User Group properties apply to the AS
  • However, the Users and User groups will not appear as objects under the domain in the Automation server as they do in the ES.
  • Only the domain object will appears under the AS.  Nevertheless the permissions will be extended to the AS.
  • 14155
100% helpful (1/1)
