Does the Valve & Actuator Selection Tool work on Windows 8?
  • Does the Valve & Actuator Selection Tool work on Windows 8?
  • CraigEl
    CraigEl
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:11 AM
Valve, Actuators
Current desktop, laptop, and tablets are installed with Windows 8
Until a newer version is released, the following work-around will allow the Tool to operate in a Windows 8 environment:
To install, the program will need to detect .Net 2.0.  To do that, ensure some .Net features are on.  Internet access is required.
1.  Go to Control Panel - Programs - Programs and Features and in the upper left will be a link to "Turn Windows Features on or off"  -  click that.
2.  From the Windows Features Screen, make sure there are check boxes next to .Net Framework 3.5 and the two boxes below it as shown here:
3.  Restart Windows and then install the Valve & Actuator Selection Tool
4.  Turn off User Access Controls in Windows.  Go to User Accounts and Family Safety (Control Panel) - User Accounts  - click the link to "Change User Account Control Settings".  In the dialog that follows - move the slider to the bottom (Never Notify)
5.  Right-click on the Valve & Selection Tool icon on your desktop (from the installation in step 3) and choose "properties".
6.  On the Compatibility Tab - check the box to run the program in Windows 7 compatibility mode and the box to run the program as administrator.
7.  Run the Valve & Selection Tool program.
Labels (2)
  • Field Devices
  • TAC IA Series
Tags (2)
  • 17645
  • iportal
