Does object transfer work between Vista server nodes?
  • Does object transfer work between Vista server nodes?
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:49 AM
When a value from a object in one Vista server should be transferred to a object in a value on another Vista server, Is it possible to use object transfer?
TAC Vista 5.1.x
In general a minimum of communication between the Vista servers should be used as it is much slower then internal communication within the server itself. But it is possible to do.
Yes it is possible to have a object transfer between objects in different Vista server nodes.
  • 12016
This is a heading
