Display PDFs in webpinpoint
  • Display PDFs in webpinpoint
  • Alan_Wood
    Alan_Wood
‎2018-09-06 09:46 AM
There is a need to be able to display pdf files from within a webpinpoint graphic
Webclient
Windows XP
Windows 7
Windows Server 2003
Windows Server 2008
instructions to open a pdf file with webpinpoint
Within a graphic in Cyber Pinpoint, add a Windows Control> Web Browser object
Edit the object and go to object properties and select the .pdf to display (Change the file type drop down to all files from .htm)
It is recommended to place the pdf files in C:\program files\Continuum\NewGraphicsFiles for permissions reasons.
Once that object has been selected, it can be saved and run in Cyber Pinpoint The same object will open up webpinpoint and the pdf will display.
  • 15328
