Dip Switch 7, Card Translation checkbox settings required depending on Card Number, MIP on the DPU
  • Dip Switch 7, Card Translation checkbox settings required depending on Card Number, MIP on the DPU
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
‎2018-09-07 09:35 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-14 11:40 PM
  • Configuration help for doors on a 1284, 7920, or 7910
  • Setting up Access Control on an SCU or DPU
  • Can’t remember if Dip Switch 7 is up for the Card Number equals Individual Number without a MIP on the DPU or was that Card Translation Checked box the issue
TAC INET
  • I/NET Seven Access Control
  • SCU 1284, DPU 7920, DPU 7910
Configuration errors or failure to remember how to properly configure the door editor
SCU 1284 Yes
Large Number
Format
Yes
In Door Editor,
CHECK Using
Card
Translation
↓No   ↓No
    Card Number
equals individual
scheme
Yes
In Door Editor,
UNcheck Using
Card
Translation
7920 Yes
MIP Board Yes
Using Large
Numbers
Yes
In Door Editor,
CHECK Using
Card
Translation
↓No   ↓No   ↓No
        In Door Editor,
UNcheck Using
Card
Translation
    EPROM Yes
Large number
format
Yes
Dip Switch 7
on
        ↓No
        Card Number =
Individual Number
Yes
Dip Switch 7
off
7910 Yes
EPROM Yes
Large number
format
Yes
Dip Switch 7
on
        ↓No
        Card Number =
Individual Number
Yes
Dip Switch 7
off
  • TAC INET
  • 3916
