Digital Schedule in Automation Server does not change a bound Digital Value
  • Digital Schedule in Automation Server does not change a bound Digital Value
  • RobertAndriolo
    RobertAndriolo
  • PeterEdvik
    PeterEdvik
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:13 PM
Last Updated: Janeway PeterEdvik Janeway ‎2019-09-17 10:50 PM
Created a digital schedule in an Automation Server folder and it never changed the value of the digital value
  • Building Operation Automation Server Premium (AS-P)
  • Building Operation Automation Server Bundled (AS-B)
  • Building Operation Automation Server (AS)
Digital value bound to a digital schedule failed to change the value at a time when a scheduled event should have triggered. The probable cause is that the Automation Server time setting is incorrect.
Configure Date and Time of an Automation Server:
  1. Click on the Automation Server in workstation
  2. Go to the Date & Time tab
  3. Set the proper time zone and save the changes.
  4. Use Network time synchronization or manually adjust the time if needed and save the changes again.
Note that it might take some time before changes to the Date & Time settings affects the Automation Server system clock if you use Network time synchronization.
Tags (2)
  • 4440
  • PeterEdvik19
50% helpful (1/2)
