Different authority levels for Vista users
  • Different authority levels for Vista users
  • Jonas_Brissman
    Jonas_Brissman
  • sesa177673
    sesa177673
  • Sacco
    Sacco
‎2018-09-06 01:48 PM
Last Updated: Janeway Jonas_Brissman Janeway ‎2024-11-19 02:05 AM
Which operations are the different authority levels in Vista able to carry out?
TAC Vista
  • Vista Server
  • Vista Workstation
A user in TAC Vista have an authority level which give the user right to perform different operations and commands.
User:
(Read) . gives the authority to read objects, object attributes/values and view alarms.Default username/password = user/user
Field manager:
(Read Write) gives the authority to read and write object attributes / values, view and acknowledge alarms. The only object attribute which is possible to write is the so called default attribute, usually the value for the object. He/she may also acknowledge and change Time Charts..Default username/password = field/field
Operations manager:
(Change) .gives the authority to read and write object attributes/values and view, acknowledge, create and delete objects, disable and remove alarms. It also gives the authority to download/upload and perform operations for physical units. At this level it is possible to write all the object attributes for an object, not only the so called default attribute. However he/she has no access to functions that impact upon system security..Default username/password = manager/manager
System manager:
(Full Control) .gives the same authority as Operations manager and also the authority to change authority to units/objects and handle global objects..Default username/password = system/system
Tags (2)
  • 5228
  • JonasBrissman24
