Difference between an EBO Hotfix and an Upgrade
  • Difference between an EBO Hotfix and an Upgrade
  • PeterLarsen
    PeterLarsen
  • CraigEl
    CraigEl
Spock PeterLarsen Spock
‎2025-10-13 08:41 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-13 08:42 PM
Users and customers often confuse the terms hotfix and upgrade when discussing updates to the EBO platform. This article clarifies the distinction to help with proper planning and communication.
  • Building Operation Automation Server
  • Building Operation Central Server
  • Building operation MP, RP and other upgradable field controllers.
The confusion typically arises due to:
  • Similar version naming conventions (e.g., 4.0.1 vs. 4.0.1 CP1).
  • Lack of awareness about the scope and impact of each type of update.
  • Misunderstanding of the validation requirements for regulated environments.
  • Assumption that all updates require the same level of planning and downtime.
EBO Hotfix or Consolidation Point (CP)
  • Purpose: Targeted fix for specific bugs or issues.
  • Scope: Minimal — typically affects only a few files or modules.
  • Impact: Low risk; does not change the database schema.
  • Versioning: Minor version change (e.g., 4.0.1 → 4.0.1 CP3).
  • Use Case: Applied when an issue needs resolution without waiting for a full release.
  • Installation: Quick and simple; may not require full system downtime.
EBO Upgrade
  • Purpose: Introduces new features, performance improvements, and broader fixes.
  • Scope: Comprehensive — affects multiple components and may include database schema changes.
  • Impact: Higher risk and complexity; requires planning and validation.
  • Versioning: Major or minor version change (e.g., 4.0.1 → 5.0.1).
  • Use Case: Planned system enhancement, often requiring customer approval or validation.
  • Installation: More involved; typically requires backups, downtime, and post-upgrade testing.
  • PeterLarsen25
100% helpful (2/2)
