Device Administrator SSL Certificate Validation Failed
Select a Country
  • Device Administrator SSL Certificate Validation Failed
  • RandyDavis
    RandyDavis
  • Robert_Davis
    Robert_Davis
Robert_Davis Contributor
‎2019-12-19 02:07 PM
Last Updated: RobertAndriolo Champion ‎2021-11-25 03:29 PM
The SmartX server has a "?" under the server name field and shows the error "SSL certificate validation failed!" as the server state in Device Administrator. In some instances, this may cause a failure to upgrade of the SmartX Server displaying these symptoms.
  • Building Operation Device Administrator
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
The SmartX Server is added into Device Administrator over HTTPS 443 but does not have a valid SSL certificate installed.
  1. Change the connection from HTTPS 443 to HTTP 80
    1. This can be done by clicking into the server settings (click on the "?")
  2. Create a trusted chain between Device Administrator and the problem SmartX Server using a self-signed certificate by following this workflow
  • RobertDavis19
79% helpful (15/19)
