What are the default access-level passwords for a MicroNet Touchscreen?
Satchwell MicroNetEnvironment
MicroNet Touchscreen controllers
Default passwords are required to access various levels of functionality on the MicroNet Touchscreen. These passwords may be changed during system configuration.
| Access Level | Default Password |
| Read Only | 1234 |
| Read/Write | 4321 |
| Super User | 1024 |
| ACK Alarm | 2513 |
🔧 Note: These passwords can be modified using VisiSat software. To view or change them, connect to the Touchscreen and check the password settings under its properties.
