Default IP address of a SmartStruxure Lite MPM
  • Default IP address of a SmartStruxure Lite MPM
  • sesa139513
    sesa139513
  • DavidChild
    DavidChild
‎2018-09-06 10:08 AM
EcoStruxure Building Expert
MPM
What is the default IP address of a SmartStruxure MPM?
Out of the box, the default IP is 10.50.80.3 subnet mask 255.0.0.0
This should be changed to suit the project requirement.
  1. Log into the controller using the default IP address.
  2. Edit the Ethernet setting, changing the IP address, Subnet Mask and Default Gateway.
  3. Click save.
  • EcoStruxure Building Expert
  • 14117
