Database and Workstation Initialization
  • Database and Workstation Initialization
  • David_Kendrick
    David_Kendrick
  • Dave_Shore
    Dave_Shore
‎2018-09-06 01:02 PM
Last Updated: Admiral David_Kendrick Admiral ‎2023-06-02 01:05 AM
What is the recommended process for Database and Workstation Initialization
Andover Continuum
  • Database Initialization
  • Workstation Initialization
Sometimes it is necessary to do Workstation and/or Database Initialization eg. following a Continuum service pack install
Database initialization
LAN systems (SQL is on a separate SQL server PC)
  1. Close all connections to the database (all cyberstations, webclient servers etc.)
  2. Open "Database Initialization" from Start/All Programs/Continuum
  3. Select "Server"
  4. Select "Update Existing Database", ensure Database Information is correct, fill in User Login Password
  5. Usually Enhanced Alarm Logging and Enhanced Alarm Delivery are ticked.
  6. Then select Continue
Stand Alone (Single User) systems (SQL is on a CyberStation PC)
  3. Select "Stand Alone"
WorkStation Initialization
  1. Close the CyberStation on the PC being initialized (other CyberStation can be running)
  3. Select "Workstation"
  4. Check both tabs and fill in the User Password
  5. Then select Continue
See the Continuum Installation manual for further information
NOTE 1
With the some domains the following has been found
- XP - "Right click" on the "Database Initialization shortcut" and “Run As” use local admin
- Windows 7 - "Shift" & "Right click" on the "Database Initialization shortcut" and “Run as a different user”, use local admin
To log on use the workstation name followed by user eg. WSUK1AB123ABC\dave
NOTE 2
Long CyberStation names can result in the error "Workstation name with invalid characters. Please enter it again"
In this case use a shorter name, below 16 characters is best.
This can occur even with an existing longer CyberStation name.
Tags (2)
  • 6655
  • DavidKendrick23
