DMS OPRIF 11.6 Freezes When Tunneling with Niagara R2 or G3
  • DMS OPRIF 11.6 Freezes When Tunneling with Niagara R2 or G3
  • CraigEl
    CraigEl
  • sesa116877
    sesa116877
‎2018-09-06 02:19 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-19 07:59 PM
DMS OPRIF version 11.6 locks up when attempting to tunnel with Niagara R2 or Niagara G3.
TAC IA Series
  • OPRIF 11.6 with a Windows OS.
  • I/A Series Niagara R2 and G3
The default installation path for OPRIF 11.6 is excessively long for Windows OS, causing the application to freeze during tunneling operations.
  • During installation, avoid the default directory:
    x:\Documents and Settings\username\Local Settings\Temp
  • Instead, install OPRIF into the root folder of the desired drive (e.g., x:\).
  • The installation path can be specified in the extraction screen during setup.
  • TAC IA Series
Tags (4)
  • 4249
  • CraigEllis25
  • drive
  • oprif
