DC1100 / DC1400 general problems after initial start-up.
  • DC1100 / DC1400 general problems after initial start-up.
  • sesa125819
    sesa125819
‎2018-09-07 07:49 AM
Issues being experienced can vary, here are some examples:
  • The digital clock gains a minute every few seconds.
  • The code (0112) when entered to accept alarms, is not accepted.
  • DC1100 controller
  • DC1400 controller
The unit has not been correctly cold-started after first being powered on.
The DC1100 / DC1400 controllers must be correctly cold-started after first powering up, this ensures that the default configuration is correctly installed. Cold-start the controller using the following process:
  1. Turn off the power to the controller.
  2. Press and hold in the ENTER and EXIT keys.
  3. Power up the controller whilst continuing to press the ENTER and EXIT keys.
  4. Release the ENTER and EXIT keys.
The controller will now go through a self test programme and load its defaults.
  • To review the DC1100 / DC1400 controller overview, select here
  • To review the DC1100 controller general data sheet, select here
  • To review the DC1100 controller installation, wiring and Commissioning information select here
  • To review the DC1400 controller general data sheet, select here
  • To review the DC1400 controller installation, wiring and Commissioning information select here
  • Field Devices
  • 4794
100% helpful (1/1)
