Custom Wiegand Template
  • Custom Wiegand Template
‎2018-09-10 07:02 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:05 AM
Is there a template to help create the custom AccessFormat array?
Andover Continuum
Creating a Custom Card, Access Format array for non standard Wiegand formats
As there is sometimes confusion on the way that the bits are counted from 0 or 1 and how to use a Plain English program to initialize the array an easy way to lay out the data would be useful.
The attached Excel spreadsheet works as a template to enter the Access Format data.
Click here to download Format Template.xls.
Enter your required Wiegand format bit definition in the box at the top, then this will allow you to define the numbers to go in the AccessFormat array lower left, which automatically fills in the example program on the right.
Also see:
  • Setting up a custom Wiegand format access cardfor information on setting up an AccessFormat array.
  • Determining Custom Card formats on Deciphering Custom Card formats.
  • What is the range of Wiegand Card numbers and Site Codes I can use on Continuum? on maximum card numbers.
  • 7283
