Critical Error registry access denied when launching the Wireless Maintenance Tool on Windows 7 or Windows Server 2008
  • Critical Error registry access denied when launching the Wireless Maintenance Tool on Windows 7 or Windows Server 2008
  • Alan_Wood
    Alan_Wood
‎2018-09-06 12:40 PM
After successfully installing the Wireless Maintenance Tool on Windows 7 an attempt to launch is unsuccessful. The following error is received. 'Critical Error InitInstance() Reason : Access to the registry key
'HKEY_CLASSES_ROOT\.wmt' is denied.
Windows 7
Windows Server 2008
User Account Control is restricting access to this portion of the registry needed to launch the Wireless Maintenance Tool
Disable User account control
  1. If using Windows 7
    1. Go to Windows Control Panel>User Accounts>Change User Account Control Setting link
    2. Drag the slider to the bottom
    3. Restart the PC
    4. Launch the Wireless Maintenance Tool without error
  2. If using Windows Server 2008
    1. Go to Windows Control Panel > User Accounts> Turn User Account Control On of Off
    2. Deselect Use User Account Control (UAC) to help protect your computer
    3. Restart the PC
  • 7321
