Creating a new cardholder in webClient gives the error 'Response XML String is Corrupt'
  • Creating a new cardholder in webClient gives the error 'Response XML String is Corrupt'
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:52 PM
webClient
A modification must be made to the ServerUtils.aspx file.
  1. Have all users log out of webclient
  2. On the webclient machine, go to c:\program files\webserver folder, make a copy of ServerUtils.aspx.
  3. Edit the existing copy of ServerUtils.aspx and add the following text to the first line. validateRequest='false'
    Note: There are brackets < >at each end of the following lines in the ServerUtils.aspx file
    Original line: %@ page language="c#" inherits="WebClient.ServerUtils, App_Web_w0emuixz" %
    Edited line: %@ page language="c#" inherits="WebClient.ServerUtils, App_Web_w0emuixz" validateRequest='false' %
  4. Close Internet Explorer if it was open
  5. Log back into webclient and then create a new cardholder and no error will show.
  • 2871
