Create a new workstation within Continuum when workstation becomes corrupted
  • Create a new workstation within Continuum when workstation becomes corrupted
  • GavinHe
    GavinHe
  • Dave_Shore
    Dave_Shore
‎2018-09-06 12:47 PM
Last Updated: Sisko GavinHe Sisko ‎2023-03-22 08:09 AM
A Continuum Workstation has become corrupted and cannot be re-added
Andover Continuum
  • Continuum Cyberstation / Workstation
  • Continuum Database Initialization
  • SQL Database
Workstation will not initialize correctly and Continuum does not start correctly even though database can be seen correctly from the PC
Occasionally a workstation can get corrupted, within Continuum, such that the computer cannot connect as that particular workstation.  A new workstation needs to be created within Continuum using Database Initialization.  Consider the following:
  • During the initialization process new Workstation Name, Folder Name, Device Node ID, and Network ID are required.
  • When initializing an IP conflict may occur, requiring a manual change to the computer IP address first.
  • Once created log in using the new Workstation,  copy over any required objects from the old Workstation and then delete the old Workstation.
Please refer to How to create a Continuum Cyber Workstation for supporting information
Tags (2)
  • 7125
  • GavinHeward23
