Could not connect to Vista Server. Login error.
  • Could not connect to Vista Server. Login error.
  • Jonas_Brissman
    Jonas_Brissman
  • LeeCravens
    LeeCravens
  • Sacco
    Sacco
‎2018-09-06 01:59 PM
Last Updated: Janeway Jonas_Brissman Janeway ‎2022-08-30 05:04 AM
Error received when attempting to login to Vista Workstation:
Or, error received when trying to login to Vista Server:
Invalid entry. Username and/or password cannot be verified in the system.
Vista Workstation
The username or password is incorrect.
  1. Check the username and password and try again.
  2. Log in with the default System account (Username= system / Password= system), or any other $Administrators username.  Reset the user's password.
  3. Open Vista Server Setup and ensure the security level has not been changed on the Authority tab. If a Vista user account no longer works set the security level to "Low Level". If a NT account no longer works set the security level to "High Level".
  4. If all system level logins have been lost, contact Product Support.  Send a backup of the database to be unlocked.
Tags (4)
  • 4954
  • cracker
  • JonasBrissman22
  • ll5503
100% helpful (3/3)
