Conversion of BCX from an BCX9640 to BCX4040 or BCX4040 to BCX9640 is fails.
  • Conversion of BCX from an BCX9640 to BCX4040 or BCX4040 to BCX9640 is fails.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:17 AM
When trying to update the OS of a BCX9640 to a BCX4040, the update process seems to succeed but the controller remains unchanged after the update process completes.
Continuum indicates no errors during the update process.
  • Convert BCX
  • BCX9640
  • BCX4040
  • Update OS
  • Firmware
Incompatible bootloader.
Update the controller to the most current version of OS for the same controller model before updating the OS with the new model firmware.
  • 17003
