Controller configuration web page only partially displays
  • Controller configuration web page only partially displays
  • CraigEl
    CraigEl
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2022-01-12 05:46 PM
After successfully logging in, the controllers' web page is only partially displayed, showing broken image links and incorrectly formatted text. Resetting the controller does not resolve the problem.
SP-C Configuration Web PageSP-C Configuration Web Page
EcoStruxure Security Expert
  • Security Expert
  • SP-C
  • SP-AC1
  • SP-ACX
Incorrect controller web page files have been cached in the browser. This may occur if different controller firmware versions are viewed/commissioned on the same PC.
  1. Clear the web browser's cache and try again.
  2. Connect directly to the controllers' configuration page. For a controller with default settings, browse to 192.168.1.2.
  • EcoStruxure Security Expert
Tags (5)
  • AdamSteele22
  • AdamSteele24
  • AdamSteele25
  • cache
  • login
100% helpful (1/1)
