Controller Time Synchronization
Select a Country
  • Controller Time Synchronization
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
AdamSteele Champion
‎2020-10-25 05:34 PM
How is time synchronized between the Controllers and Security Expert Server?
EcoStruxure Security Expert
  • Security Expert Server
  • Security Expert Controllers (SP-C, SP-ACX, SP-AC1, SP-DCU)
Require details on different ways the Controllers can have their time set.
There are two methods for synchronizing time on the Controllers.
  1. Periodically updated by the SNTP Time Server configured under the controllers Time Update tab. SNTP Time ServerSNTP Time Server
    • The controller polls its SNTP Time Server every 11 minutes.)
    • A third-party NTP server such as Meinberg NTP, can be used. These servers synchronize with four or more internet time sources and are considered reliable.
    • Ensure that UDP Port 123 is open on any firewalls, as this port is required for NTP communication.
  2. Without an SNTP Time Server configured, time is updated on the Controllers by the following methods.
    1. Time is updated manually by the Operator right-clicking the controller and selecting Set controller date/time. This will set the controllers time to the current time of the Workstation.Set Controller TimeSet Controller Time
    2. Time is updated to the server time whenever a “Force Download” is initiated for that controller.Force DownloadForce Download
  • EcoStruxure Security Expert
Tags (5)
  • AdamSteele20
  • AdamSteele21
  • AdamSteele23
  • AdamSteele24
  • AdamSteele25
100% helpful (1/1)
