Controller Health Status shows Ring-loop failure message
  • Controller Health Status shows Ring-loop failure message
  • Hernan_Urueña
    Hernan_Urueña
Commander Hernan_Urueña Commander
‎2023-02-28 07:21 PM
Last Updated: Picard RobertAndriolo Picard ‎2025-05-05 05:52 PM
After transitioning TAC INET Access to Security Expert, SP-C health status shows the message "Ring-loop failure at reader expander".
EcoStruxure Security Expert, TAC INET
  •  Security Expert SP-C
  •   TAC INET Access Control
This message indicates that the ring-loop connection is not made.
For the ring-loop connection, the opposite end of the INET subLAN must be connected to Reader 2 on the SP-C.
This message can be ignored if an INET subLAN loop is not used.
  • The Ring-loop Failure error can be avoided by running a jumper wire from Reader 1 pin D0 to Reader 2 pin D0, and another jumper wire from Reader 1 pin D1 to Reader 2 pin D1 on the SP-C that is hosting the INET subLAN
If an INET subLAN loop is used, this message indicates a break in the ring loop.
Reference Guide I/NET Access Control Transition to EcoStruxure™ Security Expert (Hardware           ...
Labels (2)
  • EcoStruxure Security Expert
  • TAC INET
Tags (3)
  • HernanUruena23
  • HernanUruena24
  • RobertAndriolo25
