Continuum's "Helix YUV Codecs (remove only)"
  • Continuum's "Helix YUV Codecs (remove only)"
  • AdamSteele
    AdamSteele
‎2018-09-06 09:16 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-30 06:41 AM
"Helix YUV Codecs (remove only)" shows up under Windows "add/remove programs" after Continuum is installed. What is this and is it part of Continuum?
Andover Continuum
  • Continuum Cyberstation 2.02 and earlier
  • Windows
A Continuum Cyberstation installation brings with it several additional programs in order to run properly. These can be seen in the "Add/Remove Programs" interface.
These programs may remain installed even after an uninstall/upgrade of Continuum.
  • Helix YUV Codecs is part of the Continuum installation. The installation file is "yuvcodecs-1.2.exe" located on the CD in "..\Continuum\ISSetupPrerequisites\{1D2652A6-D9B2-43ED-8009-987E762962A2}".
  • The Codecs install is part of the SVG viewer program for WebClient graphics in Continuum 2.02 and earlier.  This was removed from the Continuum 2.03 installation.
  • If desired, this program can be removed if it is no longer in use.
  • 17102
