Continuum gets Save Object error message "You have attributes that have not been applied. Do you want to apply them now?"
  • Continuum gets Save Object error message "You have attributes that have not been applied. Do you want to apply them now?"
  • SangKim
    SangKim
‎2018-09-06 01:16 PM
When trying to change the value of point or change the description of a point and save and refresh, Continuum gets Save Object Error with the message of "You have attributes that have not been applied. Do you want to apply them  now?"
Continuum LAN Workstation
Continuum SU Workstation
There is not enough disk space available on the SQL DB Server.
Secure disk space by deleting old log data in ContinuumDB or delete unnecessary files from the SQL DB Server.
  • 6209
100% helpful (1/1)
