Continuum gets Save Object Error with the message of "You have attributes that have not been applied. Do you want to apply them now?"
  • Continuum gets Save Object Error with the message of "You have attributes that have not been applied. Do you want to apply th...
  • SangKim
    SangKim
‎2018-09-06 01:16 PM
When trying to change the value of point or change the description of a point and save and refresh,  Continuum gets Save Object Error with the message of "You have attributes that have not been applied. Do you want to apply them now?"
Continuum LAN workstation.
Continuum SU workstation
Not enough available disk space on SQL DB Server PC
Secure disk space ContinuumDB on the SQL DB Server PC by deleting old data from log tables such as ExtendedLog, AccessEvent, AlarmEvent, ActivityEvent, or ErrorEvent tables.
  • 6210
