Continuum Reports Suite does not run. User does not have sufficient privileges.
  • Continuum Reports Suite does not run. User does not have sufficient privileges.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:46 AM
Continuum Reports Suite runs under Administrator level user, but will not run under a user group to which the Administrator privileges have been copied.
User group properties were incorrectly copied from the administrator user group to the user group used in this case.
Enable all permissions for the user group attached to the user name that cannot run the reports.
Once reports have run successfully start locking down the necessary privileges in groups testing Continuum Reports between each phase.
  • 12147
