Configuring a Tridium Jace 8000 as a DHCP Server
  • Configuring a Tridium Jace 8000 as a DHCP Server
  • RandyDavis
    RandyDavis
  • David_Purser
    David_Purser
Guinan RandyDavis Guinan
‎2023-09-14 08:57 AM
on ‎2023-09-14 08:57 AM
DHCP server is required to assign addressing to IP devices
TAC IA Series, EcoStruxure Building Operation
  • I/A Series Jace 8000
  • I/A Series ScheniderMPx Modules
  • Building Operation Multi-purpose VAV
  • Building Operation Multi-purpose Controller
  • Building Operation Room Controller (RPC) 24 V
  • Building Operation IP-IO
When working with the SchneiderMPx modules for engineering Spacelogic devices, the Jace can be used as a DHCP server for the field devices.
This video discusses how to;
- Configure the second IP network port for DHCP server use
- Add an additional IP Port to the Jace station
[video]
Labels (2)
  • TAC IA Series
  • RandyDavis23
100% helpful (1/1)
