Configuring I/A Series MNB-1000 using Cyberstation
  • Configuring I/A Series MNB-1000 using Cyberstation
  • RandyDavis
    RandyDavis
  • PaulFr
    PaulFr
‎2018-09-06 12:10 PM
Last Updated: Guinan RandyDavis Guinan ‎2024-12-17 10:05 AM
Can Cyberstation setup and configure 3rd party BACnet devices.
TAC IA Series, Andover Continuum
  • Cyberstation BACnet
  • I/A Series MNB-1000
It is desirable to configure all products from the same software.
Cyberstation and the BACnet protocol do not allow you to do basic setup and configuration of 3rd party devices, most products will have their own configuration software or local display/ keypads for setup.
The I/A MNB-1000 BACnet controllers will require I/A Series Software to setup and configure the controllers, this can not be done through Cyberstation.
Once setup and communicating Cyberstation will be able to make changes / adjustments depending upon the PIC's statement of the device.
Labels (2)
  • TAC IA Series
Tags (2)
  • 8269
  • RandyDavis24
