Commport is not XDriver enabled.
  • Commport is not XDriver enabled.
‎2018-09-06 11:11 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:58 AM
  • Getting "Commport is not XDriver enable" error when attaching the driver file to the comm port.
  • Comm port has been flashed to enable XDriver operation.
  • Controller Options shows Xdvr Comm2:00000009 (0000)
Andover Continuum
  • BCX
  • NCI
  • NCII
  • B4920
  • XDriver
  • Comm Port
Bad controller XDriver support flash file.
1. Take the Workstation offline, edit the comm port, and set the default mode to "XDriver".
2. Go back online and send the comm port to the Controller.
3. Attempt to attach the Driver file to the comm port, if the same error occurs then contact Schneider repair department for a new XDriver option flash file.
See article Determine if a controller comm port is XDriver enabled - Communities (se.com)
Tags (2)
  • 10972
  • DavidShore22
