Commissioning first generation Continuum Controllers
  • Commissioning first generation Continuum Controllers
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 12:29 PM
When NC9900 is commissioned it does not hold the configuration settings even though the changes have been saved to the controllers configuration page.
1st Generation Controllers
  • CMX 9924
  • CX 9900, 9901, 9940
Proper controller commissioning procedure was not followed.
When commissioning a first generation network controller, the controller must be rebooted (power shut off and then power restored) once the changes have been made to the controller configuration via a PC using a terminal emulation application.
Tags (4)
  • 7674
  • connect
  • direct
  • logon
