Collect log files from Project Configuration Tool 2.0 (PCT 2.0)
  • Collect log files from Project Configuration Tool 2.0 (PCT 2.0)
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2025-05-12 08:12 AM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2025-05-14 07:21 AM
How to collect log files from the Project Configuration tool 2.0.
When contacting Product Support about issues with the PCT, log files should be provided.
Collect log files through the Web interface on both Windows and Ubuntu installations:
  1. Logon to PCT server, Click Diagnostic
  2. Click Collect logs
  3. Log starts collecting.
  4. After the log collection process is complete, the file will either be saved to the browser's default download location or a window will pop up asking where to save the ZIP file. Select the desired location then click Save
Log collector tool for PCT for Ubuntu:
If the PCT web interface is unavailable, you can use the Log Collector tool to gather log files. This tool is included with the PCT installation on Ubuntu, eg. pct-2.1.1.8-log-collector-ubuntu.
  1. Give the file proper permission to be able to run as an executable either using chmod command:
    chmod +x pct-2.1.1.8-log-collector-ubuntu​
    or via file properties, as shown in below screenshot:
  2. Run the log collector tool.
    ./pct-2.1.1.8-log-collector-ubuntu​
  3. A zip file containing the required log files will be saved in the same folder where the log collector tool is located.
Labels (2)
  • Project Configuration Tool
Tags (2)
  • MahmoudSayed25
  • StephenYang25
