Changing the IP Address in Cyberstation
  • Changing the IP Address in Cyberstation
  • Alan_Wood
    Alan_Wood
‎2018-09-06 12:19 PM
Site needs to change the IP address in Cyberstation
  • Continuum
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
There is a need to be able to change the IP address in Cyberstation
  1. Shut down Cyberstation
  2. Go to the PC's network/LAN/TCPIP connection properties and enter the new static IP address
    Verify the IP address change by going to Start>Run>Cmd (DOS Prompt) and type Ipconfig/all. The IP address will show under the network card similar to the following:
    Description . . . . . . . . . . . : Intel(R) 82577LM Gigabit Network Connection
    Dhcp Enabled. . . . . . . . . . . : No
    Physical Address. . . . . . . . . : 5C-26-0A-45-7C-D8
    Autoconfiguration Enabled . . . . : No
    IP Address. . . . . . . . . . . . : 192.168.203.2
    Subnet Mask . . . . . . . . . . . : 255.255.255.128
    Default Gateway . . . . . . . . . : 192.168.203.1
  3. Launch Cyberstation
  4. Open the Workstation object using Continuum Explorer (Right click>Edit)
  5. Click on the "Teach" button (Distributes the New IP address to the controllers)
  • 7999
