Change a door name when there is an * in Netcon
  • Change a door name when there is an * in Netcon
  • Tom_Poovey
    Tom_Poovey
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:37 PM
How to change a door name when there is an * in Netcon.
All versions of I/NET Seven Software
The name that the save file has does not match what is currently in the controller.
The * represents a change either on the controller's database or what is currently on the resident I/O Points.
  1. Verify that the name on the Resident I/O Point is the correct one that is needed.
  2. Connect to the controller and penetrate down to the DPU Level.
  3. There would be an * next to the door in question.
  4. Modify the door and change it to the desired name.
  5. It can also be deleted and a + sign will be displayed in the cnf column.
  6. Saving that plus sign ensures that everything is system is correct again.
Note: When the delete is used, it will remove this door not from the Tenants, Groups and Individuals. They would have to be revisited and saved again.
  • TAC INET
Tags (2)
  • 7425
  • names
