Cannot override Microzone II points from TreeTech. An "rtdispla, No user found" error is received.
  • Cannot override Microzone II points from TreeTech. An "rtdispla, No user found" error is received.
  • CraigEl
    CraigEl
‎2018-09-06 12:43 PM
Points can be overriden in the field using PSI; have verified the standard 'USER' and 'PASS' login for all Microzones and the LCM; the GCM is able to be downloaded successfully.
Still having trouble with overriding points in a Microzone II via TreeTech. It returns error 'no user found'.
TreeTech
Network 8000 Microzone II under GCM
The date in the GCM & any Microzone/PEM controllers must match that in the PC with TreeTech since the password to access the controller is calculated based on dates.
The date in the GCM & any Microzone/PEM controllers must match that in the PC with TreeTech since the password to access the controller is calculated based on dates. If TreeTech can't Login, you can't override the MZ2. Check the dates in the PC and all devices match and correct if necessary.
  • TAC IA Series
  • 7252
