Cannot discover wireless devices in MPM controller.
  • Cannot discover wireless devices in MPM controller.
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 09:07 AM
MPM controllers, any version
The Pan ID was set correct under the ZigBee Configuration property.  However when viewing the Pan ID setting under ZigBee Configuration, the Pan ID entered in the Settings box does not match the one displayed in the Current Configuration box.  The Zigbee Configuration Pan ID has somehow become corrupted.
Reboot the MPM controller.  If a reboot does not clear the issue then the controller will have to be restored to factory default settings.
- Backup the MPM controller and then restore the MPM back to its original factory setting.
  • EcoStruxure Building Expert
  • 17597
0% helpful (0/1)
