Cannot Add Trends to a Controller
  • Cannot Add Trends to a Controller
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:07 PM
Adding a Trend to a controller and an error comes up saying that the memory is full
I/NET Seven Site
memory full error when adding a Trend to a controller
Follow these steps to trouble shoot and see if it will resolve itself.
  1. Check the memory on the PC and controller itself to see if the error is valid.
  2. Check the masking etc. on the points as well as the Trend Extension for the correct cell number.
  3. If you are still unable to add then please contact Product Support to receive a script that will allow you to add the Trend.
  • TAC INET
  • 1917
