Cannot Access Database error when attempting to initialize CyberStation.
  • Cannot Access Database error when attempting to initialize CyberStation.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:33 AM
When attempting to initialize Cyberstation on a workstation PC, Database Initialization says that it cannot access the database.
SQL
Continuum
CyberStation
Continuum Database Initialization
An incorrect path and name was used in the Server Name field.
  • Open the database up in SQL Server Management Studio.
  • Right click on the top of the explorer tree and select Properties.
  • The SQL server path and name will appear in the Property Window title bar.
  • 12821
