Cannot Access 2nd Generation Controller Using Default IP After Pressing IP Reset
  • Cannot Access 2nd Generation Controller Using Default IP After Pressing IP Reset
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:38 AM
Cannot access BCX controller webpage after pressing IP Reset.
  • Controller Web Page
  • Default IP
  • IP reset
IP reset button was not held down for a sufficient time to reset the controller IP address.
Was able to login to the controllers config page once the controllers IP Reset button was held down for a full 60 seconds.
  • 12593
