Can two Continuum Security Keys be installed on the same computer?
  • Can two Continuum Security Keys be installed on the same computer?
  • AdamSteele
    AdamSteele
‎2018-09-06 01:03 PM
Want to install both Continuum LAN key and webClient Server Key (WEBC-PRO) to enable both Cyberstation and webClient functionality on the same computer.
Continuum Cyberstation
webClient Server
Want to merge two functions of Continuum onto the same machine to save the cost of one computer.
No, you can only install one Continuum Security Key on any PC. In a LAN environment you will need to have the Continuum Cyberstations and webClient Server on separate computers.
To have both the functionality of a Cyberstation and a webClient Server on a LAN system will require two PCs.
  • 6650
