Can the pop-up windows on the WebClient Server be closed or hidden from the users view?
  • Can the pop-up windows on the WebClient Server be closed or hidden from the users view?
  • AdamSteele
    AdamSteele
‎2018-09-06 12:16 PM
Can the ACWebProxyServer and XML Automation Server pop-up windows be closed or hidden from view?
WebClient Server
The user wants to close or hide these pop-up windows.
The ACWebProxyServer and XML Automation Server applets are an integral part of the WebClient Server and are required for WebClient to run properly. There is no way to hide them from view other than to minimize to the taskbar.
  • 8088
