Reusing NETWORK 8000 (ASD) or DMS (MicroSmart) Wiring for BACnet MS/TP Communication
  • Reusing NETWORK 8000 (ASD) or DMS (MicroSmart) Wiring for BACnet MS/TP Communication
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
  • sesa116877
    sesa116877
‎2018-09-06 02:57 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-19 11:28 PM
Can existing communication wiring from a NETWORK 8000 (ASD) or DMS (MicroSmart) system be reused for a BACnet MS/TP trunk?
TAC IA Series
  • NETWORK 8000 (ASD) cable
  • DMS (MicroSmart) cable
  • BACnet MS/TP
ASD and MicroSmart cables were designed for lower baud rates. BACnet MS/TP networks often require higher speeds, which these cables may not reliably support beyond 9600 or 19200 baud, especially over extended distances.
  • Reuse Conditions:
    • ASD and MicroSmart wiring can be reused for BACnet MS/TP only at 9600 baud, and possibly 19200 baud under limited conditions.
    • For higher baud rates or longer cable runs, replace with BACnet-compliant cable.
  • Recommended Cable Specifications for BACnet MS/TP:
    • Type: Shielded twisted pair
    • Gauge: 18 AWG or 22 AWG
    • Impedance: 100–120 Ω
    • Capacitance: ≤ 30 pF/ft (98 pF/m)
    • Maximum Length:
      • 9600 baud: up to 1200 m (4000 ft)
      • 38400 baud: up to 1200 m (4000 ft) with proper cable
    • Examples: Belden 3105A, 3106A or equivalent
  • Ensure proper network biasing and termination when reusing existing wiring.
  • If communication issues persist, migrate to recommended cabling standards for BACnet MS/TP.
Cable Specification Comparison
Parameter ASD / MicroSmart Typical Cable BACnet MS/TP Recommended Cable
Type Unshielded or basic twisted pair Shielded twisted pair
Gauge 22–24 AWG 18–22 AWG
Impedance ~70–90 Ω 100–120 Ω
Capacitance ~50 pF/ft (164 pF/m) ≤ 30 pF/ft (98 pF/m)
Shielding Often none Foil or braided shield
Max Segment Length Designed for ASD baud rates 1200 m (4000 ft) at 9600–38400 baud
Examples Legacy ASD/DMS cable Belden 3105A, 3106A or equivalent
  • TAC IA Series
Tags (2)
  • 2651
  • CraigEllis25
