Can the SEC-TE communicate directly to SE8600?
  • Can the SEC-TE communicate directly to SE8600?
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 08:45 AM
I have package units with point count that exceeds the SE78600 capacity, can I simply add the SEC-TE in order to complete I/O points requirements?
SEC_TE
MPM
SE8600
Unfortunately, the SEC– TE can’t be used as extended I/O modules with the SE8600 however; you may use SEC-TE with the MPM-UN.
SEC – TE can not communicate directly with the SE8600. However you can use the SEC-TE with the MPM-UN.
  • EcoStruxure Building Expert
  • 18129
