Can the Personnel Import Utility update existing Personnel only and not create new Personnel objects if they do not already exist?
  • Can the Personnel Import Utility update existing Personnel only and not create new Personnel objects if they do not already e...
  • AdamSteele
    AdamSteele
‎2018-09-06 08:37 AM
PIU
Need to be able to only modify existing Personnel and not create new ones when performing Personnel import with the PIU.
The way the PIU handles this, to modify existing Personnel or if none exists to create a new one, is "functions as designed". There is no way to stop a new Personnel object from being created when it is unique.
Tags (3)
  • 18735
  • file
  • transformation
