Integrating Network 8000 Microflo or CVV-80000 Controllers with Niagara R2 GCM Driver
  • Integrating Network 8000 Microflo or CVV-80000 Controllers with Niagara R2 GCM Driver
  • CraigEl
    CraigEl
  • WaynePeters
    WaynePeters
  • sesa119747
    sesa119747
‎2018-09-06 02:37 PM
Last Updated: Administrator CraigEl Administrator ‎2025-12-14 09:15 PM
Can Network 8000 Microflo or CVV-80000 series controllers be integrated using the Niagara R2 GCM driver?
TAC IA Series
  • Niagara R2
  • Network 8000 controllers connected via GCM-84000
  • GCS bus communication
Clarification needed on architectural compatibility and integration method between Network 8000 controllers and Niagara R2 using the GCM driver.
Yes, integration is supported.
  • The Network 8000 controllers connect to the GCS bus of a GCM-84000 controller.
  • The GCM database contains VVBOX blocks, which interact with Microflo controllers.
  • These VVBOX blocks can be read and written using GcmGeneric objects within a Niagara R2 UNC station.
Key Notes:
  • Ensure proper configuration of VVBOX blocks in the GCM database.
  • Use GcmGeneric objects for data exchange between Niagara R2 and Network 8000 controllers.
  • TAC IA Series
Tags (2)
  • 3496
  • CraigEllis25
