Can the MF41-6043 actuator work with the DMS MicroSmart MSC-V-511 controller?
  • Can the MF41-6043 actuator work with the DMS MicroSmart MSC-V-511 controller?
  • JohnBoehmer
    JohnBoehmer
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 05:59 AM
The customer is replacing a defective actuator on a hot water reheat valve downstream of a VAV box.  The VAV and associated hot water valve are controlled by a DMS MicroSmart MSC-V-511 controller.
Can the MF41-6043 actuator be wired into the MSC-V-511 and control the valve?
DMS
MSC-V-511
MF41-6043
Defective actuator is discontinued and cannot be swapped with an identical, working one.
The triac outputs on the MSC-V-511 can properly control the MF41-6043 actuator.
  • Terminals D1 to D4 provide 24 Vac which is the voltage required for the actuator.
  • Look at the MSC-V-511 installation guide (F-25710) on page 18 for details on how to wire and program the actuator.
  • Remember that the MSC-V-511 provides 24 Vac power so there's no need for an external power source.
  • If needed, the MF41-6043 installation guide has wiring diagrams on page 6.
  • The actuator requires 2.3 VA. The digital outputs on the MSC-V-511 can provide up to 12 VA.
Labels (2)
  • Field Devices
  • TAC IA Series
  • 14303
