Can not create objects in the root folder.
  • Can not create objects in the root folder.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 11:02 AM
Get error message "access denied" when trying to create a objects in the root folder in Vista Workstation.
Vista server and Workstation 5.1.7
If open "Authority" for a object in Vista the "Database owner" is specified.
Usually the "Database owner" is $Administrators in this case it was the System user for the Vista server object.
Change the "Database owner" in the Vista server object by clicking on " Take ownership" to $Administrators from system.
  • 11345
