Can not connect to a Remote SQL server 2008 R2 from Vista
  • Can not connect to a Remote SQL server 2008 R2 from Vista
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 01:06 PM
Can not connect to a Remote SQL server 2008 R2 from Vista.
Locally where the SQL server is installed it is working fine.
Vista 5.1.6
SQL server 2008 R2
To connect remotely to a SQL server some additional settings must be set, see resolution below.
  1. Open the SQL server management studio, open the properties for the SQL server, go to connections, make sure "Allow remote connections to this server" is marked.
  2. Open "Security" in the properties, make sure the correct server authentication mode is marked.
  3. In the firewall open port 1433 and 1434 which is the default ports used by the SQL server.
  • 6549
This is a heading
