Can More Than One Sigma Server Report to Sigma Clients?
  • Can More Than One Sigma Server Report to Sigma Clients?
  • CraigEl
    CraigEl
‎2018-09-07 11:16 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 11:56 PM
Users may want to configure Sigma clients to communicate with multiple Sigma server sites simultaneously.
Satchwell BAS & Sigma
Sigma server and clients.
Sigma architecture is designed to support client-server communication with a single active server connection at a time. This limitation is due to routing and session management constraints within the Sigma system.
A Sigma client can only connect to one Sigma server at a time.
To switch between servers, use the Start Sigma Client utility. This tool allows users to manually select which Sigma server the client should connect to during startup.
  • Satchwell BAS & Sigma
Tags (2)
  • 5075
  • CraigEllis25
