Can an xdriver be run on Comm 4 of a CX9200 with it the comm port set to AutoSet?
  • Can an xdriver be run on Comm 4 of a CX9200 with it the comm port set to AutoSet?
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 11:02 AM
Must add XDriver to a CX9200 where all other ports are being used.
  • xdriver
  • Comm Port
  • CX9200
  • CX9300
As soon as the port mode switches from xdriver to some other mode the xdriver file is detached and must be reattached to the comm port for the xdriver to work.
The default mode of a comm port that is being used with an xdriver must be hard set to xdriver.
  • 11349
